265/60/18 Tire Recommendations?
Old Apr 19, 2009 | 01:33 AM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Originally Posted by lkchris
So any folks on these forums fail to understand that ALL (even ML, GL, and R) Mercedes are designed as Autobahn stormers, and high-mileage tires are incompatible with this concept.
You know, I've actually seen video of Germans using a GL off-road, at low speeds no less. Sure, she handles beautifully on the highway at high speeds, but I believe they were engineered beyond that one capability. IMHO. And I do believe they were using off-road type tires, ones that most probably are not terribly high speed rated (though most probably load rated nearly the same).
Mercedes has compromised a bit for the USA market and electronically limits the top speed of most models to 130 mph, i.e. the limit for H-rated tires.
Seen that in Europe, too, so not just here (top speed limiting, that is).
"Camry-ization" of Mercedes is regrettable, but it's been going on in the USA since before there were Camrys. So many of the 1970s 450SLs had their V-rated Michelins replaced with Sears Roadhandlers, for example. The whitewalls went well with the whites belts and shoes.
Oh, dear. Well, you've told them!
STP
Old Jul 28, 2009 | 12:37 PM
sy1216's Avatar
GL450
265/60R18 Bridgestone Dueler H/L Alenza
So what is the answer for putting 265/60R18 Bridgestone Dueler H/L Alenza on a GL450 with 18" wheels?
