Heat scavenger setting is cool! (warm)
Old 02-24-2009, 06:04 PM
Brocktoon's Avatar
GL 320cdi, Chevrolet Avalanchero, GLE 350 (on order)
I had never tried the climate control scavenger setting before today, and it works very well. I knew about it all along, but I had never tried it. Kinda weird to walk up to your GL and hear the heater fan blowing with it off and all locked up, but it is toasty, and the engine heat seems to be replaced very quickly. Very cool feature.
Old 02-24-2009, 06:07 PM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Whisky-tango-foxtrot is a heat scavenger? Is that something that's probably only in very cold climes?
STP
Old 02-24-2009, 07:21 PM
Brocktoon's Avatar
You turn the car off, and before you exit, you press the A/C button. The light comes on, and the heater motor runs, pulling residual heat from the heater core/engine for 30 minutes, or until the battery starts to get low.
Old 02-24-2009, 07:44 PM
CommanderCody's Avatar
2016 GL63 & 2008 S550
Ha!
I use the same feature to keep the cool air circulating in the vehicle if I ever find myself waiting in the car on a warm day. If you've been running the air, and you press the button (I think it says "REST" just below the A/C on the button) it pulls the residual cool air in from the AC system.
Old 02-25-2009, 09:00 AM
No sh ... kidding! I'll have to check that out. These cars are just full of little surprises.
STP
Old 02-25-2009, 10:14 AM
Kaumajet's Avatar
2008 GL320CDI
Use it when dropping my little guy off at preschool. Usually takes about 10 minutes by the time I get him out of his winter wear, signed in, his lunch put away, chat with the yummy mummies, etc. Car is still toasty when I get back in
Old 02-25-2009, 01:12 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
Old 02-25-2009, 01:15 PM
oknish's Avatar
Originally Posted by CommanderCody
Ha!
That could be handy in SoCal So you turn the car off and then just press the "REST" button? Does the red light come on or does it go off? Does it turn off if you open the driver door?
Old 02-25-2009, 01:20 PM
Brocktoon's Avatar
Red light stays on, the feature stays on for the full cycle even after you have opened the door(s) and locked the car.
Old 02-25-2009, 08:58 PM
MomsBenz's Avatar
2011 GL450
I had no idea we had this feature. I am going to try it! It works for both heat and cool? And it is just the rest button? Do you press it before or after you turn off the engine? TIA
Old 02-25-2009, 09:52 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
I like the hidden single malt scotch dispenser too!
I've had a few moments when I read the label "A/C Rest" and the light is on (when driving) and I think I've turned off the A/C. Then I remember what the 'rest' part of the label is for and think I'm a dummy.
Old 02-25-2009, 10:03 PM
Brocktoon's Avatar
After.
Old 02-25-2009, 10:04 PM
Brocktoon's Avatar
Give the AC a rest and save the ozone layer?
Old 02-25-2009, 10:21 PM
oknish's Avatar
Actually the button is labeled "RESI' with an I. And, it stands for, come on, give it a try, it is easy......RESIDUAL. Go figure.
From the manual -
Switching the residual heat on/off
It is possible to make use of the residual heat of the engine to continue heating the stationary vehicle for up to 30 minutes after the engine has been switched off. The heating time depends on the set interior temperature.
The blower will run at a low speed regardless of the airflow setting.
If you activate the "residual heat" function at high temperatures, only the ventilation will be activated. The blower runs at medium speed.
Turn the key to position 0 in the ignition lock or remove it.
To switch on: press the button.
The indicator lamp in the button lights up.
To deactivate: press the button.
The indicator lamp in the button goes out.
The residual heat automatically switches off after around 30 minutes or if:
  • the ignition is switched on
  • the battery voltage drops
Old 02-26-2009, 11:34 AM
Comfy_Couch's Avatar
2008 GL 320 CDI
OK, this probably gonna be a forehead slapper, but I've never been able to figure out what "REST" stands for. Is this some German shorthand for something? Someone, please put me out of my misery.
Old 02-26-2009, 11:40 AM
2008 GL 320 CDI
Never mind - I see Oknish's informative post now above - RESIDUAL! D'oh!
Old 02-26-2009, 02:11 PM
Newbie_2_MB's Avatar
2014 GL 450
Thanks Nish!
OK, I always thought it said "Rest" as well. When I have the heater on when driving the car, I press the "rest" button to shut off the a/c. Why should I run the a/c while using the heater? Yes, I know it helps with keeping the condensation levels steady in the car, but I don't live in a humid area.
Old 02-26-2009, 03:01 PM
2008 GL 320 CDI
Typo? Sure looks likes "REST" to me.
PS For those tech-savvy posters out there, how do you get an image into your actual message, as opposed to an attachment?
File Type: pdf
Old 02-26-2009, 05:02 PM
oknish's Avatar
You're right, Comfy. The button is labeled REST. I sorta remembered the sales guy telling me about this "residual" heat/cool feature and I assumed it was labeled RESI till I just put my nose to it.
My bad.
Old 02-26-2009, 07:15 PM
MomsBenz's Avatar
2011 GL450
After.
Old 02-26-2009, 07:46 PM
My bad.
As in "this is how to get the REST of the heat from your engine in to your car." (Or sumfin)
Old 02-26-2009, 09:58 PM
My bad.
Saved me a trip to the eye doctor - thanks Comfy.
Old 02-27-2009, 05:23 PM
AsianML's Avatar
2007 E63
REST stands for "Residual engine heat utilization". Somehow.
Old 02-28-2009, 05:32 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
What's german for the acronym 'REST'?
Old 03-02-2009, 11:02 AM
"Really
Everybody
Should
Trythis."
Don't forget, it's installed in Alabama. So it should say "RYAT," or "Really, Y'All Aughtta Tryit!"
STP
Quick Reply: Heat scavenger setting is cool! (warm)
