Lowest Height Setting - How low is it?
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
Does any owner here have some pics of a GL at the lowest height setting?
Do you think this one seems to be too low? Some suspension issue or is it lowered (which is hard to believe since it's an SUV) or ...?
Any inputs is appreciated.
http://cgi.ebay.com/ebaymotors/SUPER...7%7C240%3A1318
2008 GL 320, 2007 Silverado LTZ C3500 Duramax Turbo Diesel
I think the photos make it seem too low but I doubt that it has been modified. ParkPlace is a reputable dealer. I bought mine from them, and it is nearly identical to this one, including mileage. Have the wheels been chromed or is just the photos that make them appear that way?
Thanks for the reply...
So yours is not that low even on lowest setting? If I'm not mistaken, there should be only 2 height setting... and the one in your sig is the lower setting, right?
Anyway, yes, the wheels are chromed... I don't mind switching them w/ yours LOL.
2017 Rolls Royce Wraith, 1999 CLK Cabriolet, 2023 Genesis G90
Zoink: It seems to me from all the negative camber I see on all four wheels that the vehicle in the pictures has been lowered. I can lower my 550, and it indeed induces some negative camber in the front suspension, but the one in the picture seems a bit exaggerated. It is nice-looking, however. Good luck in making your decision.
2021 Tesla M3SR+, 2017 GLS550, 2011 E350 Bluetec, 2007 GL450 (GONE), 2003 E500 (GONE)
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Equivalent settings
It is not necessarily so that anything has been changed on the vehicle physically to lower the ride, even if that has been done.
I just Sold my Audi allroad -
The Airsuspesnion computer measures each of the ride height settings above a Datum that is set into the vehicle management computer.
If I recall it is set in mm between the centre of the wheel hub and some reference on the suspension.
Now the Datum can be changed by Anybody with the servicing software and the appropriate cable.
Quite a few people 'hacked' their allroad to both lower and heighten the ride.
It was easy to do, and easy to put back to factory spec.
SO: IF the ride height of this GL has been altered, it may be as simple as plugging in a laptop and setting the datum back to factory spec.
