GL550 tires bow outward at bottom
09 GL550, 04 SL55, 01 SL500, 01 Jaguar XJR, 02 Escalade, 87 IROC Conv, 87 Z-28 Conv, 86 IROC, 85 Eld
IS it normal for the tires to bow outward- they are no vertical but have a slant to them? It looks like the camber is off. It is a new car so tires have no wear yet.
Is this normal?
Is this normal?
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
It is possible that a slight appearance of bowing is normal; I'd ask both the dealership service advisor and whatever answer you get from him, compare it to either a trusted independant mechanic or tire shop. Just to get two opinions. I know that while sometimes a slightly odd appearance to the tires' position is normal, poorly adjusted suspensions and wheels will very quickly give odd wear and tear to the tires on a truck driven the way we drive.
1 Post
CLS55 AMG w/PP030
Its called camber. That is normal. Helps the handling in the turns. GL has pretty high negative camber thus the wheels bow outwards from the bottom. Ever seen a X5? It has even more.
Dealer looked at it
All, thanks for your knowledge. Alignment was fine - the camber is supposed to have the outward bow at the bottom. The alignment tech though did adjust the rear height and said it was too high.
