Service Costs
Old Aug 27, 2009 | 06:36 PM
BSB's Avatar
BSB
gl
Service Costs
How much do services on GL 320 cost?
I understand that the spare's tire was omitted as that place was taken away for the ammonia receptacle.
Has anybody bought a spare tire/ donut tire for long travels?
Old Aug 27, 2009 | 07:10 PM
sinnginn's Avatar
camaro ss
look at your owners manual?
Old Aug 27, 2009 | 09:09 PM
StevethePilot's Avatar
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Umm ... how would that help?
Old Aug 28, 2009 | 04:09 AM
sinnginn's Avatar
camaro ss
If you look under the cargo floor,and u see the kit to change your tire,then there is a spare tire in the back.this is news to me if a mercedes doesn't have a spare donut,or inflatable tire in the back somewhere,could be on the inside right quarter trim also.
Old Aug 28, 2009 | 09:58 AM
43221B's Avatar
15 GL550
This is for those new to the GL and this board:
No, there is no spare on the GL320. No room because of the urea tank. The runflats have extra strong sidewalls to protect against rim damage before and after getting a flat. Not a perfect solution, but acceptable. I have a tire repair kit, pliers, and a compressor that I store by the Urea tank to fix punctures. I have fixed three flats in the past on other vehicles with tire pucture tools and have had excellent results. You can actually take the nail out and repair the tire in less time than it takes to swap out the new for the spare. Obviously that doesn't solve the problem if your tire comes apart or if you hit a 4x4 at night, at 70 mph, running the width of the freeway (which I've done). Hopefully, the $300+ tires that the GL320 has on it won't be too prone to tread separation. The pressure monitor should help with avoiding that as well. Letting your tires run with low pressure in hot weather at high speeds is a major cause of tread separation. A relative of mine flew one of the medical helicopters in Las Vegas and spent a lot of time picking up people between Las Vegas and the CA border. The common variables in almost all case were underinflated tires, high speed, hot weather, and heavily loaded vehicles. The TPMS should help reduce the problem on our cars.
Old Aug 28, 2009 | 10:08 AM
sinnginn's Avatar
camaro ss
My Bad on the spare tire issue,looke like if you really want an option on a vehicle(CDI),you have to make a trade off /loose something else.
Old Aug 28, 2009 | 02:44 PM
zoink's Avatar
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
'07-'08 320 has spare tire (I think full size... need to check ).
'09+ (bluetec) doesn't have one.
The one OP referred seems to be '09+.
Old Aug 28, 2009 | 03:10 PM
sinnginn's Avatar
camaro ss
Yep,ur right the bluetecs doensn't have a spare.I guess the jokes on me,I work there at the factory and just realized that.lol
Old Aug 28, 2009 | 05:14 PM
lkchris's Avatar
'10 CL550, '12 GL550
They cost what YOUR dealer charges for them.
Ask them.
Old Aug 29, 2009 | 01:31 PM
I don't think it's full size - mine has the model/brand on the side, it says "Krispy Kreme."
Old Aug 29, 2009 | 02:19 PM
lkchris's Avatar
I changed the donut spare for a full-size spare on our E-class.
There isn't room in the spare tire storage area to do same for the GL.
