Transmission Service $$?
Old Dec 22, 2009 | 12:06 AM
atwal's Avatar
2013 Land Cruiser, 2007 GL450 [SOLD], 2007 Toyota Tundra Double Cab 4x4 Limited, 2009 Corolla LE
We are due for our transmission service, differential/transfer case fluid change. I got a quote from MB of Sacramento and it around $640+tax. How much are folks paying for this service? It was $375 for Tranny fluid exchange with new AT filter and gasket and $265 for differential/transfer case fluid change.
I know there is no dipstick on the 722.9 and only way to fill the fluid is via fuild exchange machine. This will be one not for a DIYers. I can probably do the trasfercase and differentials by myself. Any other DIYers tried this yet? Any thoughts?
Thanks in advance for your partcipation and input.
Regards
Kamal
Old Dec 22, 2009 | 12:23 AM
atwal's Avatar
Pictures of drain and fill locations.
Transfer Case
Front Differential
Transmission Drain plug
Attached Thumbnails Transmission Service $$?-100_4640.jpg   Transmission Service $$?-100_4652.jpg   Transmission Service $$?-100_4642.jpg
Old Dec 22, 2009 | 01:42 PM
lkchris's Avatar
'10 CL550, '12 GL550
Make sure they use the latest version of the transmission fluid.
Old Dec 22, 2009 | 06:00 PM
MBtech1098's Avatar
10 speed bicycle
There is only one fluid available at all the US MB part's depots for the 722.6 and 722.9 which both use the same fluid now.
And not only does it need to be filled with a machine from the bottom, but it also needs to be checked at specific temps, depending on what trans pan you have.
Old Dec 22, 2009 | 10:22 PM
wlee69's Avatar
'13 CLS550, '17 Q7, '11 G550
I know the transmission fluid is supposed to be changed at 40K...but the differential/transfer case fluid is supposed to be changed at the same time also???
Old Dec 23, 2009 | 05:35 PM
MBtech1098's Avatar
10 speed bicycle
Yes the transfer case has the same interval, there is no recommended maintenance for the diffs, but it would not be a bad idea to change it at the same time.
Old Dec 23, 2009 | 08:53 PM
atwal's Avatar
I going to have this done at Star Motors (Sacto) at local shop that is run by a former MB Tech/manager. Schedules are busy to book a weekend appointment due to holidays. I am gona have it done early next year.
Old Dec 25, 2009 | 09:50 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
I was told I'm due for transmission service and brake fluid replacement on my GL and was quoted a total of $650 for both.
