Play DVD+R/DVD-R/DVD+RW/DVD-DL DL on RSE?
Anyone has successfully played double layer discs on RSE/COMAND? Which brand of disc and software did you use? Thanks in advance!
2010 E350 Coupe, 2010 GL350 Bluetec
Saw your post, took 2 discs to the car and gave them a try just now:
Disc 1: Melody DVD-R Dual Layer 8.5 GB
Disc 2: Philips DVD+R Double Layer 8.5 GB
Both played no problem!
These were copied DVD movies using "CloneDVD2". I use "AnyDVD" to play DVDs from different regions as well. With it installed, I believe the region code is removed during the copying process.
