Rear Liftgate not closing completely
Old Apr 18, 2023 | 03:11 PM
geo51576's Avatar
GL 450
Hi, did you ever get an answer to this question? My trunk closes half way and goes back up, it feels like it's struggling a little on the way down.
Old Apr 18, 2023 | 03:20 PM
geo51576's Avatar
GL 450
Old Apr 18, 2023 | 03:23 PM
Miguk_Saram's Avatar
'07 GL450
Check your liftgate pump for proper fluid level. It is located in the spare tire compartment, beneath the carpet, within a plastic casing on the right side. Just unscrew the reservoir nut and add fluid until level with the plus sign (+) on the reservoir.
You can refill with any hydraulic fluid (hydraulic lift jack fluid works well). Be sure to open & close the liftgate several times after refilling; then loosen the screw to release any trapped air, and recheck the fluid level.
Old Apr 19, 2023 | 07:43 AM
geo51576's Avatar
GL 450
thanks Miguk_Saram, I will give that a try and will report back. thanks again for your response!
Old Aug 23, 2023 | 12:40 PM
Bmjackson76's Avatar
2012 gl450
Lift gate partial closing
Originally Posted by iandelcaribe
My GL-450 will start to close the tailgate but midway will come back as if it bumped into something, but the way is clear. If I help it with my hand it will continue and close. Any Ideas?
What was your solution?
