GL Towing Demo...
I would not tow heavy without it anymore. It's expensive, but WORTH IT.
http://www.propridehitch.com/
- Mark
During the acceleration test in the video, I don't think I ever saw the tach come back down below 3000 RPM. The 320/350 engine has peak torque between 1600-2400 RPM. It is gutless above 3000 RPM. There is a lot more power available that he isn't using. He should be letting it shift earlier. I wish the transmission was programmed to shift earlier itself, but it isn't.
This is why a CVT is so cool, you never have to "start over" going through each gear. A diesel revs so low and makes power so early, do the math, at 1800 rpm it would take you forever to hit freeway speeds with the ratio range the CVTs run in.
The CVT definitely sounds compelling.
Many thanks. My maiden tow will occur next month when I tow my Porsche to CO. 1k mile trip through the mountains.
