GL450 trailer hitch installation
The ESP is supposed to control some stability situations by applying the trailer brakes first. If it doesn't recognize there is a trailer, it can't do that. Be careful what you do, it is possible to create an unsafe situation and not even know you did.
As I understand it, the trailer brake output on the back of the truck is routed to the harness under the dash (or rear compartment on vehicles built in '06) terminating with a green connector. This connector receives its signal from an aftermarket brake controller and routes the braking signal to the trailer connector.
I'm in the process of figuring out exactly what I need to install a brake controller for my 07 GL450 and I'm still not clear on why the SAM needs to be replaced. My truck provides indication of trailer light status when I have a burnt out light and prevents the high suspension setting so I know the current SAM recognizes when a trailer is connected.
What additional function would an updated SAM provide when using a trailer brake controller?
Clearly, surge brakes cannot be compensated by the ESP program since it has no 'knowledge' of when they actually apply. Likewise, the ONLY way the ESP even has a chance of creating stability (absent a pretty exact knowledge of the mass of the trailer) is it's measurement of the towing vehicle yaw rate characteristics under actual stability conditions. According to the sales books I read at the time I bought my GL, the ESP program takes these into account in 'deciding' what to do under pending skid conditions. It is only logical, that, since the SAM unit 'knows' the trailer is there, and has brakes, that it apply those brakes first. Any trucker will tell you of the surprise if he sees his trailer coming 'round to meet the front of his truck - thus he always hits the trailer brakes first. I have never had the 'luck' to push the MB system to it's limits and check it out!
Most of those units are inertial - they look for two things: 1) an active brake light circuit, and 2) an inertial measurement of the tow vehicle slowing down.
The SAM is not in the actual brake activation circuit - it's only in the brake light circuit. The brake controller (Tekonsha Prodigy RF, in my case) is what actually applies current to the brake circuit.
What the SAM is most likely doing is braking one or the other of the tow vehicle rear wheels to counteract yaw.
- Mark
This was everything that came with it. Heavy duty beam for each side, including wiring. I thought it was going to be different, since on other peoples' posts I did not see exact one and the extra parts. Questions...
1. Anyone have ideas on the extra items?
2. Do I need to disconnect battery when connecting to rear SAM? (Per dealer's checking VIN, I was told that I did not need new SAM. It does have a spare plug space).
3. Are there detailed instructions, with illustrations?
4. When I take the bumper off, do I need to disable the sensors? I want to make sure that nothing gets messed up. Thank you!
5. One of the wires is ground, another plug goes to rear SAM and two fuses. I am not sure what slots the fuses go into go into? There are many different colors.
Yea it will be much helpful if you let me know where the plug goes to. Since the cable kit don’t come with any instructions.
thanks in advance!
