Wheel Sensor
Old Dec 3, 2010 | 12:31 PM
arcatureta's Avatar
Mercedes Benz GL450 2008model
Wheel Sensor
My ABS and ESP dashboard lights have been popping up and off on their own. Mechanics just informed me I have to change the four wheel sensors...........pls whats that?
Old Dec 3, 2010 | 04:59 PM
pcasey06's Avatar
1995 gt
The ESP and ABS systems use the wheel sensors as one of their inputs. If any of them are inopperative it will flash your ABS and ESP lights. In some cases it will cause both system to not work, cause they are not receiving correct information. Are all the sensors bad?
Old Dec 3, 2010 | 07:32 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
arcatureta - are you in or out of warranty on your '08? Wheel sensors count pulses that vary in frequency when the wheels turn. Without consistent information the ABS and electronic stability programs don't have good info with which to work. Clearly they are a safety system input. Should be covered by warranty.
Old Dec 3, 2010 | 10:47 PM
mdadgar's Avatar
2011 GL350 Bluetec, Irridium over Black Leather
I would be very, very surprised if one of the wheelspeed sensors was bad, let alone all four. They are Hall-effect sensors and they basically don't fail.
What DOES happen is that they end up with little metal particles all over them over time. They usually just need to be cleaned off. The mechanic should know that.
- Mark
