Ambient lighting
Old Dec 25, 2010 | 09:43 AM
Mazza's Avatar
Gl 350
Ambient lighting
Hi guys I need some help I have a 2011 350 gl, I would like to adjust the ambient lighting, I like it to be brighter. I tried the button next to the R button but no luck, has anyone been successful? Getting it brighter...Thank you so much in advance!!!!
Old Dec 25, 2010 | 02:04 PM
fs1013's Avatar
2010 E350 Coupe, 2010 GL350 Bluetec
The two buttons on the instrument cluster adjusts the brightness of the cluster itself only.
To adjust the brightness of ambient lighting, it needs to be done from the on-board computer. Play with the buttons on the steering wheel and you should find "ambient light" under the "lighting" submenu. You can adjust from level 0 (off) to level 5 (bright). This is described in the operator's manual.
Not sure how bright you wish to have. Level 5 isn't that bright to me. But I guess that's why it's called ambient lighting.
