Residual Heat comes on automatically?
The strange thing is I did not push the REST button -- yes I am sure. And it was over a hour after I turned off the engine. When I opened the passenger front door, it turned off. Same thing happened once before. I can't tell if this is a malfunction or does this automatically if the engine is very hot to cool it off.
Does anyone know?
The REST button will use the engine's residual heat to continue to blow warm air for a while (I remember seeing maybe an hour in the manual) after the engine has been turned off. I know my old SL did the same thing with the A/C & it knew which you were last using.
Thanks,
Will
Does anyone know?
I have also noticed I will go out to the garage a while after shutting the GL off and the rest will be running and I definitely did not turn it on. Manual was of no help.
I did not have automatic on 2008 GL but have it now on 2011 GL after speaking to service they confirm it.
I had some issues of bad odour coming from vents on 2008 due to humidity but so far good this winter in 2011 nice clean air for now.
