gl320cdi start up acceleration problems
Thanks for help.
Thanks for help.
Thanks for help.
Unlikely to be a fuel filter if the problem 'goes away' after a restart. Plugged filters don't fix themselves that way!
Lack of power going up hills may be caused by the Engine Control Unit (ECU) not putting enough fuel in because it believes there isn't enough air from the turbo. This can be caused by a sensor going bad [mass air flow, temp, pressure, etc]. It tries to match the fuel flow to the air flow and if it doesn't think there is enough air, it cuts back on the fuel. A sensor going bad also fits the intermittent nature of the problem (runs fine after restart).
Good luck
I'm not going to even think about taking it to the dealer until I can make the problem happen 'on demand'.
