Trouble with Valentine V1 Radar
14 GL550; 14 E63s
I have a V1 mounted high on the front windshield just left of the rearview mirror and for some reason I'm having difficulty picking up signals that are in front of me. I've swapped it out with another V1 and same problem. I sent it back to valentine and they said it was fine. They said the behavior is suspicious of a metallic film or tint on the window which I certainly did not put on. The unit works fine in my C-class.
Anyone else have issues like this?
2011 GL450 P2, Appearance Pkg, Leather. 2012 C250, P1, Sport, AMG Wheels, Panorama Sunroof.
do you have the ir glass on your GL? That can cause the interference you are speaking of.
14 GL550; 14 E63s
So what's the solution if my GL550 has the "blue" glass? They said with IR glass there are 3 non-coated spots.
I had to find the little square (you can see it outside the car) that is located a little to the right of center in my S-Class in order for my Valentine to work correctly.
GL550
