Noise from COMMAND unit
Old Oct 30, 2011 | 10:27 PM
dchou4u's Avatar
GL450
Smile Noise from COMMAND unit
On my 2008 GL450, whenever I turn on the COMMAND unit, I hear a high pitch sound coming from the unit. It is not very loud but I can definitely hear it when the car is not moving. Once I turn off the COMMAND unit, the noise stops. It sounds like a motor or something in the COMMAND unit making the sound.
Is this normal or is there something wrong with the COMMAND unit? I even popped out the Nav DVD and the single CD and the sound is still there. So the sound is not coming from a spinning disk or something.
Old Oct 31, 2011 | 08:41 AM
newyorktoLA's Avatar
2020 G63, 2021 E450 All-Terrain Wagon
It's normal at least in my opinion. I have the same high pitched noise. if I put my ear closer, i can hear a fan too.
Old Nov 3, 2011 | 01:02 AM
Max Blast's Avatar
NGL450 w/EORP, S550
I can hear a low computer like buzz. Not noticeable unless I'm listening for it.
Old Nov 3, 2011 | 07:29 AM
alx's Avatar
alx
It is the cooling fan in the back of the head unit. Somewhat normal. Eventually they start to squeal and stop or just seize quietly.
Old Nov 3, 2011 | 10:33 AM
dchou4u's Avatar
GL450
Cool
It gives out a rather high pitch sound. Quite annoying. Not sure if it really is normal. Hard to imagine that it would do this while it was still new.
Old Nov 3, 2011 | 10:49 AM
alx's Avatar
alx
if you are still under warranty you can have the headunit replaced.
if not, you can have it pulled out and the fan lubricated.
Old Nov 3, 2011 | 11:01 AM
dchou4u's Avatar
GL450
Talking
It is still under warranty. let me go and have them take a look. thanks for all the feedback.
Old Nov 10, 2011 | 06:53 PM
dchou4u's Avatar
GL450
Red face
When to the dealer and they said it is normal sound from the head unit. But I am surprised that it can be called normal sound.
Again, when I turn on the COMMAND unit, I hear a high pitch sound right away, then it is followed by another sound that sounds like a cooling fan or something.
Can you guys confirm if your GL450 have the same sounds coming from the COMMAND unit? It is very noticeable when you turn the COMMAND unit on without turning on the engine.
