Small leak
Old Nov 9, 2011 | 03:40 PM
mbmama's Avatar
GL 450
Small leak
I have this small leak i see couple drops every week, I'm not sure if I need to concern at this point. Can someone tell where this leak coming from? Can it be a DIY fixed? Please see the picture.
Thanks.
Old Nov 9, 2011 | 07:11 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Are we looking at the underside of the radiator? Is that where the leak seems to be dripping from?
Old Nov 10, 2011 | 10:30 AM
LEOSOPHIE's Avatar
GL550
That looks more like a brace. You need to first identify what type of fluid it is. Engine oil, power steering-transmission or coolant. Fluid leaks blow around so they aren't always easy to locate. Some shops use dye to locate.
Old Nov 10, 2011 | 11:24 AM
alx's Avatar
alx
your truck has warranty- right?
what are you doing taking pics of the undercarriage?
Old Nov 10, 2011 | 11:25 AM
atwal's Avatar
2013 Land Cruiser, 2007 GL450 [SOLD], 2007 Toyota Tundra Double Cab 4x4 Limited, 2009 Corolla LE
My guess is - it's power streering as it is not coming from transmission pan or transmission fluid cooler lines. Power steering fluid can be verified by checking the fluid in the canister to see if level is correct. You can clean the underside with oil degreaser and then trace where the leak is coming from. Good luck and keep us posted.
Old Nov 10, 2011 | 11:26 AM
Stigzmate's Avatar
2007 GL450, 2002 BMW 330i, 1973 Triumph Trident
Good advice regarding the need to identify the fluid.
Looks like the brace located between the engine and transmission.
If I remember well this is where I saw engine oil dripping as a result of the camshaft plug leak. If this proves to be the source of your leak then this issue has been discussed on here before. The parts are cheap and it's certainly a DIY for most capable home mechanics. Of course, if you're under warranty or CPO the dealer will do this at no charge.
