winter oil weight??
As a side note, I just had an argument with my dealer about the "plug" for the block heater. Apparently on my spec sheet it says I have a block heater but then I have to pay another 150.00 for the plug in order to use it. As with every other vehicle that I've bought that has a block heater, you dig out the cord from somewhere and plug it in. Why would MB put in a block heater yet not include the plug to use it??? Needless to say I didn't pay for my plug but I have to get my husband to find where to attach it....
Regarding a block heater - I've never heard that one could be had on these engines. Is it only put on if the vehicle is going to Northern BC or central Alaska? There are several members on this forum who live 'up North' and I've heard nothing that would indicate that a block heater is necessary or desirable. Again, ask your dealer to show you the exact location where the plug is so you can show it to your husband. I'll bet he can figure a way to connect power to it if, in fact, it is there.
And, to answer your question, it seems to be the height of stupidity to install a block heater as an extra cost option and then NOT provide the appropriate plug to make it work. Go to the dealer and lodge a complaint that the car didn't come with all the required pieces that you paid for - the plug in cord!
Here's a list, and some of the lighter weights you can get:
http://bevo.mercedes-benz.com/bevoli...nt_action=show
I am in Calgary, and have never had a problem with the standard oil weight. You may want to add a boost of antigel to your fuel tank if you plan to leave it out over a few nights.
As for your block heater, what year is your car? This whole added cost plug business I thought only applied to 07 and early 08? Mine came with it, my pal's 08 just a few vin numbers older did not. He had to pay for his.
Is your car a Canadian model, or did someone import it?
I think this is a difference of phrasing. Mobil 1 is the only oil, to my knowledge, that has gone through the MB certification process to be "approved" per MB. That does not mean other oils meet / do not meet the relevant spec; they just haven't spent the money to become certified. So everyone's right and wrong.
"We recommend using exclusively the products in the following lists that have been checked and approved by Mercedes-Benz because:
design parts and operating fluids are tailored to one another,
damages that occur due to the usage of non-approved operating fluids are not covered by the warranty.
The approval by Mercedes-Benz is noted on the containers, for engine oils: e.g.: MB-Approval 229.51
Because the vehicles/major assemblies and operating fluids are constantly developed further, the MB BeVo are continuously updated in accordance. The current version can be found on the following pages. Thus, only the online version of the Mercedes-Benz Specifications for Operating Fluids released here is valid."
I don't know what is is about Americans and Mobil 1, they must have some pretty strong marketing down there, because almost every car forum I join, I'm invariably told that "Mobil 1 is the only approved oil", while my dealer is doing oil changes with Elf Solaris or something...
This is a canadian truck and I've taken it to Northern BC, as of right now it's -26 outside and heading colder....winter is finally hear, another 5 months before we begin to thaw out...
If anyone knows of an install video link pls fwd...
tks
- Mark, in sunny California
tks
Not much difference between 0W and 5W
Also, no need and not such a good idea to lower the second number, i.e. stay with 40. But it means that ALL MB-approved oils are year around oils.
I once compared all versions of Mobil 1 and ALL except 15W-50 had the SAME cold pour point, i.e. -55 degrees F IIRC. That is 0W, 5W, 10W all the same. 15W-50 was something like -45.
Get the cord for your block heater.
And finally, comparing a Mercedes diesel engine to some 'merikun iron or the like is totally irrelevant. Apples/oranges. Don't do it. It's embarassing.
This because gas engines always run at stoichiometric fuel/air ratio while diesels change speed because they get richer mixture. The gas engine is always running around 15/1 air to fuel, while a diesel at idle is running maybe 150/1, i.e. it's hardly burning any fuel. A warmed up diesel will actually cool down if left idling and some manufacturers, i.e. Navistar, offer computer routines to affect a high-speed idle should this occur.
