Rear window washer fluid
Mine is 09 GL450.
I have to turn the switch 3~4 times to get the rear window washer fluid.
It did work if I turn the switch just once for 3 years. The dealer checked and told me that 09 GL450 is not equipped with a check valve in the line, so they have to get special permission to do this. I'm waiting a call from them.
Anyone had same problem before? or any idea?
Thanks in advance.
Thanks in advance.
'09 SL Black, '12 ML63, '13 SL63, '14 E63 Wagon, '14 458 Italia
Sounds like a mechanical issue (pump / line) of some sort. In my '09, it does take a couple seconds for the fluid to make its way back there.
