FRACK! The slow leak in my tire was a nail in the sidewall!
Old Feb 6, 2013 | 08:17 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
So I had a very slow leak. Just a couple of PSI every couple of days.
But since I was getting ready to go out of town, I figured I would get it fixed so my wife would have no concerns if she needed the GL.
I'm thinking rim leak or bad valve stem.
But NOoooooooooo
Well, #^%@@%$&^%&^ %$@$#$$%& $@#$$#@*&#$!!!
The slow leak is a small nail in the sidewall where it can't be fixed.
There goes $650 I really did not want to spend!
Old Feb 6, 2013 | 11:11 PM
aggst1's Avatar
2011 GL450, '06 R500 traded, '08 ML350 sold
But NOoooooooooo
I know exactly what you are going through. Same exact thing happened to me back in September. I even started a thread on it. I wasted $650 for a new run flat oem tire and now I m told I need to replace all tires. The other three are on their last legs. I should have spent $1000 or so from the beginning and replaced all four with conventional tires. Run flats are junk.
Old Feb 7, 2013 | 02:46 AM
stickygreen's Avatar
'97 E320
Bridgestone Runflats in 275/50/20 are only about $250 each, and I find them better than the $500 Goodyears. If you're anywhere near Northern/Central Ca, I've got a couple extras with 95%+ tread (factory takeoffs with a few hundred miles) that I'd let go for $200/ea
Old Feb 7, 2013 | 08:13 AM
N_Jay's Avatar
I am not on Run-Flats.
These are just the normal 275/55-19., but the set is about 2/3 worn, so not bad enough to just say "Oh well" and buy 4 tires, but not good enough to just buy 1 tire.
Actually, I just remembered the previous owner mentioned he has a warranty, so the bad tire will get replaced "free" ("Free" means Mounting $17 and new warranty $33. Still better than $280) but I have to buy the second tire, so it will probably be only about $400 out of pocket.
Old Feb 8, 2013 | 11:04 AM
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
I picked up a set of Bridgestone run flats with 6K miles a few years back for $100 each. There are deals around but you have to watch for them.
Old Feb 8, 2013 | 11:10 AM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
I remember this deal....have u had a chance to use them or u still keep them in your garage ?
Old Feb 8, 2013 | 11:52 AM
chsu74's Avatar
Hi There! It is still in my garage. We put on about 7 to 8 thousand miles every year on the truck so the original Good Years are still fine. It will get installed this Fall before winter comes. Stay safe this weekend.
Cheers
Old Feb 8, 2013 | 05:40 PM
N_Jay's Avatar
Almost decided to pick up a use pair off ebay to save a few dollars, but went with the new tires.
