Glowplug replacement
Hi, Is there a standard mileage/duration for when they should be replaced?
Also are they easy to replace? Thanks |
Not common. What are the symptoms?
none, just checking
glow plugs are not a wear item on the x164 platform.
One of mine died at 125,000 miles on a 2008 GL. I went ahead and replaced all. Can't remember what it cost for labor. I bought the plugs themselves from rm european.
I read somewhere that the CDI engine does not need glow plugs to start unless temp is below zero. Is this true?
