Glow plug relay & module/contoller
Old Jun 4, 2013 | 06:04 PM
nicktampa's Avatar
2008 GL320 CDI
I have a code of P0672 which the autozone description shows #2 cylinder glow plug, faulty connection, or glow plug controller connection. Any ideas which specific error P0672 is?
Thanks, Nick
Old Jun 5, 2013 | 01:53 AM
AmoMB's Avatar
S Class
does the glow plug light come on after car has started/while driving?
Old Jun 5, 2013 | 05:57 PM
nicktampa's Avatar
2008 GL320 CDI
The glow plug light and the check engine light come on after start, a few seconds later the glow plug light goes out and check engine stays on continuously.
Old Jun 6, 2013 | 02:02 AM
AmoMB's Avatar
S Class
Does it start okay or does it crank a few times before starting in the mornings?
Old Jun 6, 2013 | 04:58 PM
nicktampa's Avatar
2008 GL320 CDI
It starts fine, all the time. I am in Florida where it is warm (hot) actually.
Old Jun 6, 2013 | 05:07 PM
AmoMB's Avatar
S Class
It seems very likely that it is the glow plug module, they are a common failure on the GL. I just replaced mine with similar symptoms. Easy to install and cost about £120.00
https://mbworld.org/forums/m-class-w...cel-p0672.html
Old Nov 6, 2015 | 12:14 AM
  #32
MSAB51's Avatar
2008 E320 Bluetec, 2008 Lexus RX400h, 2012 Honda NC700SA, 2005 Acura MDX, 2000 Mercedes ML320
My 2008 E320 bluetec is showing these similar start problems now at 120k miles. The car would start instantly before, even at -30 to -40 C (Minnesota and Ontario winter) previously. But recently, even at reasonably warm temperatures (10-20 C) it would need multiple cranks, show the ignition and check engine error lights. Codes shown have been p0671, p0673 and p0670, at different instances. But they all go away and the car runs great the rest of the day, often for a few days, until the problem shows again. Should I just change the glow plug module or also all the glow plugs? I don't want to be stranded in the winter. Thank you very much for suggestions. Also, are these easy DIYs?
Old Nov 6, 2015 | 09:58 AM
  #33
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Since it gave the controller code, I would certainly try that first.
