SDS - MultiPole ring sensor Error - BAS ESP - Rear Right .. What is that ?
Old May 12, 2013 | 03:07 PM
mz3bo's Avatar
Hi,
My SDS is showing the error in the title. It says the values are not plausible. Now, I changed the Speed sensor (abs sensor or rpm sensor or what ever they call it). Even when the new sensor in place, cleared the code and drove1/4 mils and blam... ESP, ABS error... Same error again. Tried to spray some cleaner in the whole where the ABs sensor sits in but no luck.
What can be wrong.
Thanks for you time
Old May 12, 2013 | 08:11 PM
alx's Avatar
alx
Check wire where it is routed above thr axle along the upper control arm. It gets pinched and continuity is broken. This is a known problem.
Also make sure sensor is installed properly, connector is clean on both sides and your battery is fully charged.
