wheel bearing
Old Jun 18, 2013 | 07:36 AM
a2j's Avatar
a2j
2008 GL320CDI (310k), 2017 GLS450 (170k), 2024 Sprinter 2500 (40k)
wheel bearing
Couple of days after our ~4500mi road trip (that we did in 10 days) I started to hear some noises. I could really hear it starting at 40mph and up. Faster I went, higher the pitch. So I figured it could be a bearing. Seemed like it was coming from rear, passenger side. I put the vehicle on the lift and started to listen. I'm 99.5% sure that its real left wheel bearing. New part cost little over $100. I'm thinking about doing it myself. I've done this before on a different vehicle. Has any one done this? Is there more than one bearing? Any tips/tricks? Special tools? I have access to a press.
Thank you.
Old Jun 19, 2013 | 01:58 PM
alx's Avatar
alx
before you do that - rotate tires.
seriously. i dont know _anybody_ in the real world that can tell bearing from worn tire.
you can lift truck, grab wheel at 12 and 6 and try to detect play. repeat at 3 and 9. no play- no bad bearing in 99% of the time.
my bet is tire noise rather than bad bearing.
Old Jun 19, 2013 | 02:03 PM
a2j's Avatar
a2j
There is no play. But how can tire cause noise when wheel is in the air spinning?
Old Jun 19, 2013 | 02:12 PM
alx's Avatar
alx
i missed that part... it cant. but humor me- rotate tires (front to back) and go for a drive
Old Jun 20, 2013 | 08:42 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
My rear passenger side bearing went out around 100,000 miles.
Old Aug 5, 2013 | 08:28 AM
a2j's Avatar
a2j
Installed a new bearing. Total cost for this DIY job is $105. Friend had a press at his shop. It was a little tricky getting a center piece out. The rest of easy. I've never used 18mm wrench before I did this job, I actually had to buy one.
It is now drives quiet as it was before.
