Need help with gl new head unit
Ok, I decided to put my pioneer avic in my 2011 gl450. Changed speakers to focal, jl 5 channel amp, jl sub. Had a friend's shop do it. It's finished except one thing.
You can put a dvd on from the head unit, and it plays through rear seat entertainment monitors, and the front. You can hear audio fine. Problem is if you put a dvd in the factory rear dvd player you cannot her anything through the headsets. So no way to hear any audio from rear dvd is my problem. Any ideas? |
Seems as though they ran into another problem in that the radio reception is poor, and non-existent on AM. I am thinking perhaps there are antenna amplifiers that need to be powered. Do anyone know which lead this would be for a 2010 GL450? Also I am guessing this may be related to the wireless headsets not working
Sorry no help with your questions, but can you share where you mounted the JL sub? Pics?
I think Metra sent the incorrect antenna adapter. The one that is for the GL should also have a remote power lead which powers the antenna amps. Correct connector should be here today. I will post results. Thanks!
As for sub, I bought a customer enclosure from a forum member. Sub mount replaced the first aid kit. Looks perfect in that spot, and take up no space. However, it can only fit an 8". Sounded fine with the factory system, not sure if it will be enough now though. |
ok, so adapter was not the problem. I now have weak radio reception, and no headphones. Also now I cannot set my analog clock. Gonna have to figure that out also.
GL450 antenna with new head unit
Originally Posted by desant89
(Post 5806970)
Originally Posted by StephenPage
(Post 7493596)
Did you ever figure out how to power the antenna? I'm having the same issue with an aftermarket head unit.
Follow this post here and bypass the Sirrus. https://mbworld.org/forums/gl-class-...-system-5.html
Zoom to here: 02-17-2019, 01:44 AM #117 WaveyKat |
Thanks a lot. I stumbled upon that thread shortly after my post and I'm hopeful this will do it. I've ordered a long Fakra coax cable to give this a shot.
