2008 gl550 stiff steering only sometimes
Old Nov 17, 2013 | 11:45 AM
JohnEric5's Avatar
2008 GL550
I've looked all throughout the forums and cannot find an answer to this issue. I have a 2008 GL 550 with 46k miles on it. Sometimes, not always, the steering is stiff when parking. Then other times it isn't. So I checked the level and it's ok. I took it to a Mercedes service center and there are no codes and no leaks. He suggested maybe flushing the system and replacing the fluid suggesting that at some point the wrong fluid was used. Not sure if that even makes sense
Any ideas?
Old Nov 23, 2013 | 01:42 PM
Jekudk's Avatar
Gl450
Can you tell a bit more how it feels. Mine has issues but feels only stiff for every half turn
Old Nov 27, 2013 | 02:43 PM
cab2u's Avatar
2009 GL 550
I had my power steering pump replaced twice in 60k miles. First time it was getting hard to turn. Next time all the fluid leaked out. I'll bet it is the pump.
Old Mar 8, 2014 | 11:29 PM
JohnEric5's Avatar
2008 GL550
I actually have it nailed down. It only gets tight and hard to turn when I'm driving up the three floors of my parking garage. I think all of the turning which makes me think maybe there really is the wrong fluid in the system. Its always right as I get up to my parking spot. It gets very stiff as if there is no power steering.
Any ideas?
Old Mar 9, 2014 | 10:18 AM
JediJD's Avatar
Currently shopping
Whether or not it has had the wrong fluid really isn't the issue. You either aren't getting pressure to the rack or the rack isn't responding. That is either a hose, a valve or a seal. If there aren't leaks, and the pressure and return hose are outwardly in good shape, I'd replace the pump. If it still hangs, rebuild or replace the rack.
