08'gl320cdi. No start
Old Dec 6, 2013 | 11:53 AM
Summit Benz's Avatar
Gl320cdi
Been a lurker for awhile and now have a ? Been fluctuating temps past 2 days from -22f to 0. Car started slowly yesterday but it just turns over slowly this morning with no fireing up just a couple of sputters??? Fuel gelling?
Old Dec 6, 2013 | 09:45 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Jelled fuel won't cause slow cranking - it will simply stall. Wrong viscosity lube oil for that temp might cause slow cranking. But first check to see if the original battery has been replaced [If the carpet under the passenger seat (US car) has NOT been cut, your battery is original and has given out]
Old Dec 6, 2013 | 11:21 PM
alx's Avatar
alx
You need a new battery. Even if you don't- I would start there. If original battery it's time is up.
Old Dec 8, 2013 | 05:44 PM
a2j's Avatar
a2j
2008 GL320CDI (310k), 2017 GLS450 (170k), 2024 Sprinter 2500 (40k)
If engines cranks normal during a warm start up (after you've been driving for half an hour or so) and cranks slow after sitting outside in cold for 10 hours or so, replace the battery.
Old Dec 8, 2013 | 10:18 PM
Gl320cdi
I know it sounds like a batt problem,but supposedly the dealer replaced about 10000 miles ago??? Guess I'm going to have to take a peek and check terminals too. wtf
