Need help identifying issue
Old Jan 14, 2014 | 06:01 PM
JohnAMG's Avatar
3 Porsche rotation
One of my wife's GL550 snow tire/wheel is getting a rusty brown buildup and I can't figure out the cause. I don't see any oil leakage and the suspension is working properly. The only thing I did notice is when the car is moving in the parking lot I can hear metal friction noise coming from that corner. Does anyone know what this is? The car has 52000 miles and flawless so far.
John
Old Jan 14, 2014 | 06:47 PM
mrchris's Avatar
2001 SLK 230, 2007 GL 450
Sounds like the brake pad on that wheel is down into the metal backing. Sometimes the semi-metallic pads will create brake dust that can turn rusty, but that looks like more metal than just the normal pad. Combined with the noise you describe, I think you've worn through the pad.
Old Jan 14, 2014 | 07:13 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
John
Pull it off and see what you see.
Old Jan 14, 2014 | 10:24 PM
nynd's Avatar
2018 E63S
Worn pad or rubbing pad (as you'd expect them to wear equally to some degree) so a stuck or seized calliper is probably your issue.
Old Jan 15, 2014 | 11:54 AM
JohnAMG's Avatar
3 Porsche rotation
Thanks guys for the response. I took it to the local shop and right away the shop foreman said it is likely a stuck caliper pin or pads. I will find out for sure later today.
John
