Tire Pressure Sensors Not Detected
I am skeptical that Audi was allowed to transition to indirect only. The obsession with tire pressure is entirely with the regulatory agencies, such as EPA, for fuel savings. Indirect won't tell you if all four tires are underinflated.
For what it's worth, these guys on ******* think it's cranking speed differential:
2007 GL450
It looks like the push to TPMS was rationalized by NHTSA - that is, safety - so for that indirect TPMS is more than adequate.
I recently had all 4 tire pressure sensors replaced at America's Tire with DILL 1049, but now the system just says Tire Pressure System Inoperative No Wheel Sensors Detected. They initially installed the 351MHz sensors, which were wrong, but even after replacing them to the 433 MHz sensors, the sensors are still not detected. The techs said all sensors scanned just fine.
Before changing sensors, I was still seeing the options to reset or restart the TPMS. Now it just says no wheel sensors detected. I just spent $500 for the sensors & labor and now they're asking me to take it to the dealer. They must be doing something wrong to have the system recognize the sensors.
Anyone ever had to replace their tire pressure sensors with OEM sensors? I might just have them re-install the old ones in.
Right you are; at least, it turns out indirect TPMS is allowed, even on new vehicles. I wonder why the rush to direct TPMS when the sensors are so expensive and confusing.
Problem is, as technology becomes more reliable, people rely on it more. Perhaps more than they should. We're already seeing that with (partial) self-drive vehicles. Of course, you can't tell how many blow-outs TPMS has prevented. But you sure can tell when it hasn't.
Well, I think that applies to many things. But, I think in this case, it was more due to laziness than stupidity. Also, gas station air dispensers weren't known for their accuracy.
#32
tpms
The other side of the coin is “road hazards “ how many times have you seen someone driving up the freeway with a partially inflated tire? or worst driving on a flat? they picked up a nail etc. I always check air pressure but it sires is nice to get a warning that something has happened … this is my first model that shows constant air pressure and on a hot day it is very common to see a tire increase from 32-33 to 37-38 . just some thoughts why tpms is useful .
Elbeau (05-14-2024)
#33
#34
I think we are squarely in the age of complication over innovation. Big *** screens, giant sunroofs, transmission sensors that somehow derive tire pressure, and a bunch of owners who don’t know how to check tire pressure nor keep their eyes on the road.
#35
2007 GL450
Dude watch JustRolledIn. You wouldn't believe how many people never change their oil and then are surprised when the engine goes whoomph.
Maybe this is why people buy electric cars. They think it will be like an electric appliance that works until they think it's time to buy a new one.
#36
Between my dashcam, radar detector and the vehicle's system checks, I'm treated to a light and sound show every time I turn the vehicle on.
And trying to explain it all to my newly driving wife, for whom English is a second language, only adds to the fun.
Then add in that just about everything is in a different place between our Benz and our Land Rover....
Going back to my skateboard as my primary means of transportation sometimes seems appealing. Eh, maybe not.
#37
#38
When you're getting new sensors for your car, make sure they're a perfect match for your car's make, model, and year. Even if they're the right frequency (433 MHz), they gotta be programmed or set up just right for your specific car model. It's like making sure you've got the right puzzle piece for the puzzle - everything's gotta fit perfectly.
You can purchase sensors made by Huf (BHsens) and called Intellisens that are programmed simply by getting tire pressure page on your screen between dials and pressing the R button.
They are a good thing when when you have winter and summer wheels.
Part number RDE206V21 ... FCP Euro, among others has them.
The trick is convincing your tire shop not to attempt programming them their usual way.
#39
2007 GL450
It's not that difficult.
The dash reset function in my 2007 only sets the nominal pressures to the pressures the sensors are reporting. Thus if a sensor is at 40 psi, the reset tells the system the nominal is 40 psi, and to warn if the pressure drops by a certain percentage - I think it is 20% - thus reporting an error if that sensor drops to 32 psi. One should only do the reset when the tires are known to be at correct inflation and "cold", that is, having sat for a while to cool off.
#40
Different info on my 2008
It depends on the model year. In my 2007 there is absolutely no user programming at all, and tire shops' tools neither recognize nor have any effect on the sensors, which do no two-way communicating: They simply start transmitting when the tire rotates, and the onboard receiver looks for four signals, and if it finds less than four, it reports an error to the vehicle system.
is definitely worth investing in if you have a couple of cars and get them rotated or ever have to change tpms like I did .
