Arrnot and other rear air springs
2007 W211 E350 4Matic / 2008 X164 GL320 CDI
Looks like I have a leaky airspring in the rear.
Anyone use any of the "OEM" and/or no names ones off eBay?
Anyone know any good places to get Arrnot airsprings at a discount?
This supplier sells refurbished and they guarantee their springs. Located in San Diego, CA.
http://shock-absorber.dvautoparts.co...w-jkirikoookjq
They charge more than Arrnot, and they don't seem to have the rears.
The question is considering my originals lasted 120,000 miles and 6 years, id $170 to $180 a side for Arrnots really worth it compared to no-names at $85 to $100 a side?
The other question, is do they really need to be done in pairs?
2009 E350, 2015 GLK350 4Matic
Still does not answer the question if the under $100 no-names are really any worse than the $175 Arrnots or $$$$$$ MB-OEM?
I'm not waiting that long because I don't want to kill the pump.
I have to replace a shock so I have to get under in the cold anyhow.
If I don't hear anything soon, I will be going with et cheaper one.
Cheaper option as in cheaper than Arnott? I would go with Arnott just because of lifetime warranty.
Also, my GL has one Arnott already in the front, previous owner must have replaced. Truck rides absolutely fine and I cannot tell any difference left to right, so I'd say replace just the one that is leaking. I am a fan of doing stuff like this in pairs but in this case it seems to be ok to do one at a time.
i have seen trucks work with the cheaper no brand bags.
said that - i would pay a bit extra and get the arnotts as the company is rock solid, stands 100% behind their product and you know that once you put the arnotts in that would be the last you bother with those bags
my personal x164 has arnotts in the front and back and i have no affiliation with arnott in any way. take this fact at face value.
First bag lasted 120K miles and 7 years. Guessing not many people replace them twice.
Now, the darn shock seem to be about $260 to $275. I usually do shocks in pairs but at that price I may do one and see how it rides.
Yes, that is generally the rule, but comes from the time when shocks were not designed to last nearly the lifetime of the vehicle.
MB even says they can be replaced one at a time.
I was actually looking for a used shock just so the wear would be a bit closer, but used rear shocks seem to be rare items.
My guess is because the interior need to be disassembled to remove them, and the relatively small market for used shocks, scrap yards don't bother.
Even tried Car-Parts.com, but might check a few more cross references and try again.
Even with one shock blown and leaked out, the ride is not too bad, so I am guessing a small difference between a new and a used shock will be even less.
E55, GLS450, GL63, GLE350
I'm close to 200k on my GL and the factory airbags were replaced once and now those have also failed and have been replaced with Arnott units. I would not do factory airbags/strutts again.
Parts are on the way.
One new shock and one Arnott air spring.
Now all I need is a decent day. (might buy a kerosene heater for the garage.)
You are nickle and dime-ing your mb vehicle and maintaining it on a shoestring budget. This is not going to end well. This is an observation from this and other posts of yours. I am not trying to sound elitist or insult you as I have no idea who you are, but this is not how it is done. Trust me here.
The Arnott rear airbags are not the same as the oem bags as they have a different rate. Arnott recommends to replace them always in pairs.
It was a TX car and I am guessing heat has a lot to do with the life span.
However, it was also garage kept at both ends of the commute, so probably did not get as much heat as most TX cars.
I see no reason to go with MB parts, but deciding between Arnott and "other" is a bit tougher.
The shock I ordered is a Bilstein, but that is MB's OEM anyhow, so I am not expecting any difference except the cost and a sticker.
It is a balancing act. I find I fall off both sides, spending some money for things that in the end were not needed, and other times realizing that I should have spent a little more up front.
I guess that puts me somewhere close to the balance point.
(Always learning and always adjusting)
I do agree that most people (especially in the MB world) seem to lean towards over rather then under spending.
Of course I know people who overspend maintaining their Fords and Chevys, and wonder how I drive two MBs.
Will Arnott aftermarket air suspension parts ride differently from the originals?
No. Arnott aftermarket air springs are just like the originals. You will not notice any difference in ride quality. Arnott designs its air springs with the same spring rate and load capabilities set by the original manufacturer
They are not the same as oem. They run less pressure to maintain same ride height as they are stiffer. That is one of the reasons why they are warranted for life. If you have DAS you can see by yourself what I am talking about.
The head toss will be amplified also by the fact that the old remaining bag has become further even softer with time.
Once you receive your bag read the instructions. It will say both bags should be replaced at the same time. There is a reason for that. Of course as you said since you tend to be more frugal your mileage obviously will vary.
Maybe they revised their design?
If it "bobbling" I will probably plan a new rt shock and second bag, but I am hoping it will be OK.
I've order (1) arnott bag for my left rear and plan on doing the install myself.
My question is. Should I replace both or just wait until the other starts to leak.
As the writer stated above I love the ride. Whem working a double I generally have to roll down the window to keep from falling asleep (with a ride this smooth). The dealer suggested I chamge both out at the same time. But with the install being so simple and arnott having an ample supply I didn't see the need to purchase 2.
My one bag (and one shock) are on the way, but might get installed at different times due to available time and shipping times.
Bag will be in Thursday, no word on the shock.
