COMAND unit problems....
I think there is some kind of sequence of steps that one has to do to get the vehicle back in sync when the battery is replaced.
You might want to search this forum or Google battery replacement in a Benz. I know that there are some whacky things that gets hosed up. I've seen windows, locks and sunroof and guessing there is more as you are reporting.
You might also go back to the shop and complain. If they have done enough of these they should know that some stuff needs to be reset. It's not simple a swap and go. Pray they did not hose something up in the process like cross the negative and positive posts. Real easy to do since you're working in tight quarters under the passenger front seat.
But after turning itself off. It would come back on (like everything was fine).
No other lights or alerts on on the dash. Just seemed to be possessed
I think I'm narrowing this down (I think). While the system is off I notice that the "illuminated" on button suddenly goes dark (as if power to the system suddenly stops) them the illuminated "on" button comes back on and you can hear the disk / DVD spool up , in about 30 seconds the cycle repeats itself.
With this newfound seat of the pants diagnostics I don't think it's he command system. It has to be something in regards to the constant power that's supplied to the unit.
Tonight I'm going to try disconnecting the battery cable in an attempt to reset everything I'll update with my results later.
1. Crank the car as normal
2. Press and hold down the power button for 10 seconds (I held mind down for about 20 seconds) you will start to hear one by one your six disc changer start to cycle through your DVDs.
3. Release the "ON" button and your command should start as normal.
I've been without radio/sat/nav/DVDs for about 2 weeks because I refused to take my car to the dealership and have it diagnosed for $125 an hour.
This worked for me and I hope it works for others. I Priced some replacement command systems new and used as well as searching on eBay as well as going to the Command web page. Just having to get rear aronott bags and tires for GL 550 my wife would still be strangling me now if I told her i needed to take the truck to Mercedesbenz for servicing.
Good luck and I hope this helps some that may have experienced the same.
