Timeset problem
Old Oct 30, 2015 | 02:03 AM
GLX164's Avatar
Mercedes GL X164
Unhappy Timeset problem
Hi there!
There is a small problem on my 2007 Mercedes GL320 CDi that happening on the timeset, which is keeping undo back the time when I change the time.
For example, I try to change the new time but undo back the previous time after a few seconds. Would you please show me how to fix the prob?
Thank You very much
Old Oct 30, 2015 | 02:09 AM
vsix's Avatar
JBs C63 PP( wifes car ), Mc Laren Pxx(toy), 2013 Mustang GT 5.0 ( DD ), ML 6.3 ( winter DD )...
Please explain exactly what you mean... wich buttons do you use to set the time, maybe you do everything right until you hit at the very end the wrong button?
Old Oct 30, 2015 | 10:16 AM
DennisG01's Avatar
'08 GL 320 CDI
Originally Posted by GLX164
Hi there!
Thank You very much
I'm not quite understanding what you mean, either. Do you mean that you are adjusting the time, but then it reverts to the original (wrong) time? All you should need to do is change the time on the main display and then when you exit the screen the clock in the gauge display area will change automatically. Or, at least, that's all I've ever done to change the time.
Old Oct 31, 2015 | 06:57 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Do you use the 'soft key' on the COMAND screen to access the clock set feature? If so, what steps do you perform? Do you have an owners manual, if not you can download one on line.
Old Nov 2, 2015 | 09:04 AM
DennisG01's Avatar
'08 GL 320 CDI
Just wanted to update to what I mentioned above as I just reset the clock for daylight savings. I did need to press the "OK" button. But as mentioned above, I would assume this is in a manual.
Old Nov 3, 2015 | 12:15 AM
GLX164's Avatar
Mercedes GL X164
Video descripiton about problem
Update!
The Mercedes service center solved the problem.
