just replaced my transfer case- change your fluid!
Truck has roughly 60,000 miles on it. I do tow an Airstream with my GL, not sure what impact this might have.
The transfer case fluid looked ok. Still a bit red in color. The fluid in the differentials were both brown to black in color.
Swapping out the fluids took me a lot longer than the other folks have posted here - I would say two hours start to finish for all three. It was not hard at all - it just took a while to drain, refill and clean up in each of the three areas.
A couple of things not noted in the other posts.
I put the air-matic suspension in the "raised" position before I started. This gave me enough clearance under the truck that I was comfortable working without putting the truck up on stands.
You have to remove the plastic cover from underneath the front differential to get to it. This is the same cover you remove if you have done the transmission service before. It comes out easily by removing about a half dozen hex-head screws.
I shopped on-line at Pelican Parts to get the exact weights and specs of differential fluids specified by Mercedes. So I bought two liters each of the front diff fluid and the rear diff fluid, and one liter of ATF for the transfer case.
For the rear differential, I bought Fuchs - SAE 75W-85 - MBZ Approval: 235.7 differential oil. It required about 1.5 liters.
For the front differential, I bought Liquid Moly - SAE 85W-90 (MBZ Approval: 235.0) differential oil. It required about 1.5 liters.
For the transfer case, I bought Fuchs ATF 134 - the service required 0.5 liters.
I don't see how you could cram in much more than 1/2 liter of ATF into the transfer case. I jacked up the truck on the front passenger side as another poster suggested, and it didn't seem to make much of a difference in how much fluid I could get into the TC. The fluid immediately streams right back out the fill hole, and I'm just not fast enough to trap an extra couple of milliliters in there.
For the transfer case, I bought Fuchs ATF 134 FE - the service required 0.5 liters.
PLEASE never use the air suspension to raise vehicle for working on it..
if a airbag fails the car will come crushing down on you
I was more focused on the part about using the airmatic to raise the truck enough to work under it instead of using a jack to raise it.
And should I put .75qt or .5qt?
Transfer case oil - use the red colored MB ATF 143 oil. Not the blue 134. This came from MB USA!
Diff oil - front and back diffs should have the same oil weight. Mercedes recently changed from recommending 85W-90 to 75W-85 for both the front and rear diffs. Approx 3L is all you will need to service both the front and rear.
85w-90 was deemed to thick by MB engineers I was told. So now they only recommend using 75W-85.
Hope this helps.
I just changed my transfer case fluid at 48k miles. I figure it's good preventive maintenance even if not fully needed. Real easy access. Took longer to jack up front for draining, then the rear for filling than anything. Old fluid was light and flowed easily, but brown. I replaced w/ Redline D6 ATF as I really like their products. I'll probably do the differentials soon. Should have done them at the same time, but it sounds like they can go longer w/out a change. Hopefully they are aren't low.
Reading this up-thread got me thinking...
Hope this helps.
Spec 236.15 is blue
I change mine every other oil change. Really easy and quick with a pump.
I was only able to get about 1.25 qts in each before they started overflowing. Should I go back after driving and try to top off a bit? Just seems like it would be really hard to get another .25 qt in. Oh, and too late now, but do the o-rings need to be replaced, or are they re-usable? Hope so...
this being My personal car I am testing a theory. a few notes from this repair, the plastic guide I feel was damaged from the worn/loose chain so I drilled and tapped the holes for longer bolts and reinstalled. in the single speed unit there are only bearings and a chain for moving parts,I feel that .5 lt is not enough lube and atf is a bit light. I forced 1 liter of 0w20 synthetic engine oil through the fill hole and reinstalled the plug.
In Our shop We do a lot of American 4x4 trucks and have found that a little over fill and using Synthetic engine oil in place of atf has extended the life of the units.
side note: on the 2 speed units with clutches, I would only recommend using engine oil at Your own risk.
I will watch My theory over the next few miles and see what happens.
