just replaced my transfer case- change your fluid!
Subscribe
Sep 14, 2018 | 08:25 PM
  #76
Quote: Maybe the difference between the years? My MB workshop manual lists:
22Nm for the transfer case plug
35Nm for the front diff plug
30Nm for the rear diff plug
Finally did mine today. At 64K miles, all fluids looked OK. At least with my driving style, 60K replacement interval is fine. To gain extra space, I put the truck in the raised position and put 4 jack stands all around just in case it decides to low itself. Took about 2 hours at a slow pace.
Reply 1
Sep 17, 2018 | 11:13 PM
  #77
Here's the chain is anyone needs it.
Mercedes ML W164, R W251, GL X164 Transfer Case Chain
Bearings too.
Transfer Case Bearing kit for ML W164, GL X164 R Class W251 4Matic w/o offr
Reply 1
Sep 18, 2018 | 06:15 PM
  #78
Quote: Transfer Case
Drain Plug: A0029900612
Washer: N007603016105
Differential:
Drain Plug: REUSED
Washer: REUSED
The differential drain plugs do NOT fit with washers. Rather, there are o-rings, and I for sure did not reuse 11-year-old o-rings. New drain plugs from Mercedes come with new o-rings.
on my 11-year-old car with 75k miles, both diff fluids looked like new, the transfer case fluid pretty good.
Reply 0
Subscribe
Currently Active Users (1)
