GL320 2006 limp mode
Old Jan 18, 2016 | 08:20 AM
Jaspal Gadda's Avatar
Vauxhall Corsa
Exclamation GL320 2006 limp mode
Hi All.
I have a GL 320 2006,
for some reason the Kickdown module is not active and i dont know how to activate it, could anyone help.
I am using a snap-on Solus ultra machine.
thank you
Old Jan 18, 2016 | 11:22 AM
Vauxhall Corsa
not sure... thats the problem, all i know is that the Kickdown is not active which to my understanding is the same as limp mode???
Old Jan 18, 2016 | 04:46 PM
alx's Avatar
alx
if the engine/ tranny has not reached operating temp it is possible that wot downshifts are disabled until temps are in range.
what is your issue? are you stuck in gear? check engine light on?
Old Jan 19, 2016 | 04:31 AM
Vauxhall Corsa
my apologies for not explaining my problem correctly.
when i am driving the car the gear shifts are fine but once i hit around 60mph and i put my foot down the car doesn't move, the acceleration is very slow. theirs nothing mechanical wrong with the car.
i have read on line that this is because the car is in limp move or that the kickdown is disabled, i have plugged the car into my computer and kickdown is disabled and the CAN module is also disabled and i am not sure how to active it.
