In the market for a GL
Im in the market for a GL and I have been eyeing a few 2008-2010 models (online only thus far).
I assume the 350 is better on gas mileage then the 450/550 but by how much?. Are all models the same in terms of outside looks (aside from the stock rims), and interior cabin size?
Since I am looking at a pre-owned, is there anything in particular i should keep an eye out for when im at the dealership and when i take it for a test drive?
Thanks all!
Check the air shocks but otherwise never had a problem w/ former and actual GL, I just place an order for my 4th GL, will be my first diesel...
The 350 diesel will have the adblue system which is prone to expensive problems. The 2007/2008 gl320 will be far more reliable as there is no adblue. The 350 does not get better mileage.
On all x164 you should check airmatic suspension components. On diesels you should check for oil leaks indicative of expensive problem (oil cooler seals). It is essential that if you are buying a truck with over 40k miles there is documentation that tranny oil has been changed at 37-40k miles.
