Cannot locate X25/2 (Engine compartment/Interior compartment connector)
Old Mar 6, 2016 | 02:15 PM
vladc77's Avatar
Mercedes Benz, BMW
I need to check connections in X25/2 (Engine compartment/Interior compartment connector) on Mercedes GL450, 2008. Unfortunately, I cannot locate this connector. I am wondering if someone can help to identify where is located. I looked into WIS but only found out the description but not exact place. Thank you in advance.
Old Mar 6, 2016 | 03:05 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
Located on the bulkhead inside the car under the glove box. Drop the lower dash board cover under the glove box and pull the carpet back you will see 2 connectors held together with a 7 mm nuts
Old Mar 6, 2016 | 06:42 PM
vladc77's Avatar
Mercedes Benz, BMW
Great! I will check it out. THANK YOU!
