Malfunction (Airmatic)
If you dont mind sharing, where did you order the compressor from? I checked with www.oediscountparts.com and they told me they would ship out a reman and requires the core back. Thanks
There was something inside of the pump when I shook it so I decided to open it up. Some bearings fell out of there and piston had a play of about 1 mm.
It would be nice to know if we can get parts to rebuild these.
I ordered from Arnott and paid extra for fast and reliable service. Appears to have plenty of options on eBay new and rebuilt. eBay also offers new Arnott at $100+ cheaper than price on Arnott's website. This is all found after I ordered from Arnott.
I have a leak in the reservoir on the pump and discovered the leak early. Wonder if I can find the housing to rebuild it myself to keep as a backup. The eBay rebuild kits for sale seems to be parts for the piston and not the plastic air reservoir housing.
Get the two bolts closest to the wheel bolted up first without the spring and washer and align the one bolt closest to the radiator done first. After the hardest one is done, then the other two is easy..
