P0410 Secondary Air Fault
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Ok..so, Im new to the site so, here goes.
So, I 've replaced, the pump, check valve and relay.
I've manually applied vacuum to both Konbi Valves and manually activated the pump and confirmed air flowing from the exhaust at rear of vehicle.
I can hear the pump working at start up and run for approx 90seconds then turn off.
I confirmed the vacuum switch is working by removing vacuum line (when the engine perform a cold start) and felt the vacuum suction.
Everything appears to working however, during the cold start when the secondary air pump is running, I hear what appears to be an exhaust leak or a back pressure noise in the vicinity of the passenger side Kombi valve. Odd thing is this noise goes away after approx 90 seconds when the pump turns off. I can't find any evidence of a leak.
Any Suggestions are welcome.
e0em9mlc (09-30-2016)
Alx: I'm thinking and air leak as well but, I can't find any evidence of it. I'm not familiar with the design of the system (how secondary air is delivered to the CAT). What I can see and know is the Kombi valve bolts directly to the head. I can see the passageway inside the head but, beyond that I have no idea how the air is delivered to the CAT. I assumed it's mixed inside the head and delivered through the exhaust manifold. thanks...
