Adding Rear Camera and Swapping Head Unit
Old Nov 11, 2016 | 10:25 PM
gbigpapa's Avatar
2007 GL450
Hi guys I have an early build 2007 GL450 that did not come with a rear camera. In order to add the camera I learned that my head unit would need to modified to accept a video input signal which was pretty pricy. I have an opportunity to pick up a head unit from a friends 2008 GL450. Is swapping this unit plug and play once I run wiring for the camera? Do I need to tap into up a reverse trigger signal (like the reverse light circuit) to activate the camera and screen or is this built into the 2007's existing wiring. Is there any kind of programming or coding that I would need to do to get the 2008 head unit to work in my 07 or are there any lock or theft security codes I'd need to know about?
Thank you,
George
Old Sep 25, 2019 | 09:05 AM
farkis644's Avatar
00' W210 E55 (sold), 07' W211 E63
Im guessing you already considered a unit like this? https://xtrons.com/mercedes-benz-var...-9-0-pbx79m211 It has car play and is camera ready.
I have been looking in to this a bit. These updated ones are supposed to be faster.
Old Sep 25, 2019 | 01:46 PM
farkis644's Avatar
Sorry, commented on this related post instead.
