Cold weather start?
Fishnut1
Well, you know what you said about "not knowing your vehicle"? Now I'm the one - I had no idea it was ribbed. I've never had the insulation off, but I do change the oil myself and I guess I never looked close enough. I wonder if there's enough vertical height to put one on the side (the oil would have to be at a high enough level to avoid burning out the heater, though). I'm going to look closer, myself.
Another option is the type of heater that simply splice into the lower radiator hose. Just as efficient as the "OEM" way, but much less expensive. I have never personally used these, but I wouldn't hesitate to use it. I've heard plenty of good things over the years from fiends/acquaintances/forums.
"Shield"... is that some type of skid plate? I don't think I have that - just the insulation blanket.
https://www.parts.com/media/images/o...al/F355050.gif
and this? So I would think that placing it on the lower part, is what my mechanic was thinking if this is what you have?? I personally did not pull the pan blanket off, but will drive up on some blocks, when we get back to Texas, and see what they put under my truck..??
It looks like the upper part of the pan may be flat, at least, on this diagram.. Only way to know for sure is to crawl under and verify personally.
Thanks again for checking yours...
Fishnut1
Because the oil drain is where it is, that MUST be the lowest level of the pan. I mean, I'm looking in the right place, right?
The "lower pan" on the diagram looks like it could be flat, but we can't see the underside and there could be fins there. So maybe you have exactly what is listed there and my pan is different for some reason? Or maybe there's still another explanation. I'll be curious to see what you find out.
For what it's worth, I called Wolverine and they said DO NOT put the blanket back on. Said those blankets have a tendency to catch oil (from oil changes without that quick thing I have!) and road grime. A 300*F heater in close proximity to a blanket that could possibly be soaked in oil wouldn't be good thing!
Now you have me pondering the reason you pan could be different from mine?? I am trying to think, but like 'Curley' of the 3Stooges once said..."Nothing's happening"... only this.. could your pan be an after market large capacity pan? How many qts/liters do you use in an oil change? I know that they made them for VW's in the 60's, for the old Beetles. I have one on my dune buggy, here in Baja, and it holds 5.5 liters, plus 0.5 more for the add on filter.. Hopefully, we get to the bottom of this... no pun intended
Fishnut1
I believe the last time I did the oil I used about 8 or 9 quarts. I think this is the normal amount? I've only ever seen a couple pictures or threads over the time that I've been on this forum, but I don't recall anything looking different than what I have, though. Although I can't say I was ever really taking a real good look to compare something that specific, either. I am not the original owner of this vehicle so I can't say for sure, but nothing "appears" non-OEM about it.
This is really strange. Maybe if ALX is reading this he can offer some guidance. Either that, or we need some extra help to solve this mystery...
https://mbworld.org/forums/gl-class-...ml#post6762267
Fishnut1
Thanks for the memory..........
Anyway, I'm curious too but I can't be of much help.
Fishnut1
I'm going to hoarding off the engine bay and using forced air flexible ducting from a Diesel heater to see if this works.
I'm not suggesting you shouldn't make the system better than originally designed, though.
