remove and replace starter
- Remove top and bottom bolts (11mm universal / torx socket on 12"+ wobbler extension) holding starter
- Remove heat shield from starter body - just the ear bolt. (Lesson learned - see below)
- Remove starter through a) push / pull towards forward of truck until gear clears its insertion in crankcase. At first, it may seem as if there's no forward clearance to clear crankcase. This is the hardest part, but It will come out with a little patience. Reach around and make sure wires are not binding and it will come full forward. Begin lowering and allowing starter body to rotate slightly allowing the solenoid to clear obstructions. Think corkscrew motion about inch counter clockwise facing front of truck, lowering the wire side about the same amount. You can feel the clearances as you do this as long as you are not trying to pry bar it. Once gears are clear from crankcase, drop gear side down and start working down and back. At this point I turned it sideways and rested on control arm so I could access wires.
- Remove both wires from starter
- Drop starter out full towards rear of truck - voila - done.
The heat shield is actually 2 parts, each having 1 bolt. On my first pass, I removed both bolts and took heat shield out while the starter was still installed. This worked, but you can't reinstall it this way, which I learned the hard way. Once you remove the rear bolt, the shield will slide on its clips towards rear of truck and come out. Reinstallation is the reverse of this. I had to remove starter again to attach clamp first, mount starter to crankshaft and then attach shield. Here's a picture for reference:
That pesky clip can't be hooked once starter is mounted. So, that's my lesson learned which I hope saves someone else some time.
Cheers,
Atreides
2009 GL550
Hi Atreides,
thanks for your step by step instructions. You're right on point. Took me less than 30mins to get it out.
I was putting off this project for so long because I thought I will have to lower the entire front suspension and remove part of the exhaust system to get to it.
But you make it so easy. Like you said the most important things to do is to remove the heat shield and the electrical connections to the starter and it will slide out with zero effort.
Thanks again, you're a lifeliife saver!!!
Cheers,
Atreides
2009 GL550
wife said her car won’t start... thank God it died in the driveway. It also has been hesitating to turn over for months now.
something I wanted to check before pulling the starter as it seems tedious:
1) fuse 122 is a fuse labeled as starter, when should I see twelve volts on it as I am not seeing it?
2) where is the starter relay, should I not be able to jumper 12 volts to the solenoid and here it click? If I don’t here it click I should be able to measure resistance to ground as it is a solenoid and should have significant resistance? According to rock auto parts numbers my relay part number should end in 319 or 619 which two of the relays in the box containing fuse 122 do, swapping them did nothing but I’m most concerned I’m not seeing voltage on fuse 112 when turning key to position 3/ ignition.
3) if the starter has brushes that are going bad then the battery to starter cable should read open circuit, where is that end of the cable? If the brushes make contact with the commutator and the windings are good I’ll get a significant resistance....
just want to confirm necessity and a direction for work with some measurements as I’m not as fit and young as you guys are ...
thank you in advance
-mark
Looks like homing out in my case was misleading as the ground brushes had disintegrated, since Bosch offers a lifetime warrant on their new non rebuilt starters, how does one claim warranty without proof of purchase?
Commutator scratched up by springs dues to brush disintegration... starter was less then 12 years old as it’s a 2010, in my opinion this is abnormal and a defect.
Cheers,
Atreides
2009 GL550
Three notes:
1. I didn't have a E11 Torx socket in my set, but fortunately my car's starter bolts were E12. It is easier to get the top bolt out if you remove the lower first since that frees up a bracket that allows some slack on a wiring harness that is in the way of the upper bolt.
2. The shield you remove before dropping the starter requires a fair bit of force to push free once the nut is removed. It seems like you've missed a bolt, but there are two sturdy spring clips that hold it on tightly even after the nut is removed.
3. The solenoid on the new Valeo (available from Auto Zone for $265) starter was slightly bigger in diameter than the original starter. After transferring the heat shield bracket to the new starter, the stud that holds it together didn't poke through the hole on the opposite side of the bracket enough to get it started by hand. Some large channel locks provided enough force to squeeze it together enough to get the nut started, and then I tightened it down with a socket. I didn't tighten the nut to the base of the stud because the slip joint on the other side of the bracket started to deform, and I was afraid it would pop loose. It has quite a bit of tension on it from the bracket bending, so I don't think it will be a problem down the road.
All in all, not a difficult job. A little fiddling was required to get the starter in and out, but that was about it. One of the rare jobs that was easier than expected.
Finally, I don't think the directions mentioned it, but if you don't already know, disconnect the battery before doing the job or you'll probably weld the positive lead to the chassis somewhere.
The internals of the old starter:
