GL450 Multiple Light our warning (lights are okay)
Old Mar 8, 2017 | 04:28 PM
skasu123's Avatar
ML430
I am getting multiple lights out warning on dash e.g. rear brake light, rear turn signal. All the lights warning are for rear of the car. The lights are fine. Anyone had this . . .any thoughts what to do.
This is for 2011 GL450.
Old Mar 8, 2017 | 04:55 PM
JR-GL350's Avatar
GL 350 2010
Welcome to the club, I posted a similar problem 2 days ago without any answer.
I have the rear turn light out warning and it's ok. Only that light.
Old Mar 8, 2017 | 06:25 PM
gl450x164's Avatar
gl450 530i
star diagnostic will be your friend here
Old Mar 10, 2017 | 10:09 AM
skasu123's Avatar
ML430
I noticed the rear camera shows blank screen now.
No one else had these problems? Was hoping to get some information before going to the dealer.
Old Mar 15, 2017 | 10:40 AM
skasu123's Avatar
ML430
Any one experienced this?
Old Mar 15, 2017 | 02:29 PM
crossfire190's Avatar
2008 GL 450
I would double check to be sure that the stated bulb is in fact working correctly. Other bulbs will light to compensate for the light that is out, so it may look like it is working correctly even if you do have a bulb out.
Old Mar 18, 2017 | 02:27 PM
Spartydano's Avatar
2018 GLC 300
Light out display
i have a 06 ML500. It constantly tells me I have a right or left rear turn signal out. It's intermitten & corrects itself after turn off the vehicle for awhile. This is what I've found on the forum. The tail lights are wireless sockets. They can be dirty, bad or aged, or just not connecting in the socket hole properly. You can purchase new wireless sockets & this may fix the problem as long as you make sure the socket hole is clean & not damaged. There is also a wired socket kit you can buy which is very easy to install. This seems to be the best remedy.
