CEL On GL450
I got a GL450 a few days ago and it has a check engine light - I wanted to reset the codes and see if they came back on and I used the OBDLinx LX to clear the codes but they did not clear after I tried a few times.
Is it possible to reset the codes without disconnecting the battery?
Confirmed Diagnostic Trouble Codes
-P0410: AIR System "A" (Powertrain, Generic) - Is this the Airmatic Structsagging on the driver side?
-P0432: Catalyst 2 Efficiency Below Threshold Bank 2 (Powertrain, Generic)
-P0422: Catalyst 2 Efficiency Below Threshold Bank 1 (Powertrain, Generic)
-P0015: "B" Camshaft Position - Timing Over-Retarded Bank 1 (Powertrain, Generic) - Is there not a recall on this?
Permanent Diagnostic Trouble Codes
-none
Diagnostic information provided by OBD Auto Doctor
I changed driver air struct as well as rear passenger air struct and the P0410 is gone for the last 100+ miles -P0410: AIR System "A" (Powertrain, Generic)
These codes did not appear again
Also replaced one "Bosch 0232103114 Camshaft sensor" P0015 - seemed to have been gone but reappeared again yesterday. Any tips on how to locate the faulty sensor from the 4?
Looking at replacing the magnets as well
however, the cat errors are worrisome as your cats might need replacement or due to engine timing (retard) problems they run too cold and cant reach light off temps.
