compressor or airbag
Old Jun 5, 2017 | 01:06 AM
tian8088's Avatar
2011 GL550
Hi all,
My 2011 GL550 started to give me the airmatic malfunction message, and the car will drop really low but i can still fit about 3 fingers, and when I try to raise the car with the engine running, the malfunction message turn on, and sometimes I get the compressor cooling down message too. Car doesn't go any higher though. Does this mean I need a new compressor? or it's a leak somewhere? car has about 68000 miles on it.
Thanks!!
Old Jun 5, 2017 | 01:37 AM
gl450x164's Avatar
gl450 530i
compressor is below threshold...time to replace
Old Jun 5, 2017 | 10:52 AM
alx's Avatar
alx
this. worn piston ring or cracked reservoir.
Old Jun 6, 2017 | 02:21 AM
tian8088's Avatar
2011 GL550
where are those located?
Old Jun 6, 2017 | 02:36 AM
gl450x164's Avatar
gl450 530i
you have to replace the air compressor front passenger side, many many topics on this a quick search on here or google will show you location and diy replacement
Old Jun 9, 2017 | 01:13 AM
tian8088's Avatar
2011 GL550
I know where the compressor is, I was asking for the piston rings.
Old Jun 9, 2017 | 01:22 AM
gl450x164's Avatar
gl450 530i
well then you would know that the piston ring is inside the compressor and if you need to know where the reservoir is its attached to the compressor
Old Jun 9, 2017 | 01:04 PM
tian8088's Avatar
2011 GL550
Damn I feel stupid now but thanks
