Transfer Case removal on GL350 diesel
I talked with John at Cobra Transmission and asked what he thought. He said, that without the chain guide the chain will eventually slap against the bottom of the transfer case and eventually cause a leak and or "explosion." Looking further into the matter of other Integrated Transfer Cases, most transfer cases do not have chain guides - they just have two sprokets and a chain. There are some Integrated Transfer Cases that share the similar case (like BMWs) that also use a chain guide. But after driving this car for 11K miles without a problem or leak - just knowing that my TC chain was loose and broke the chain guide along the way, I'm inclined to properly put the seals in, new chain and forego the the chain guide altogether. If in the future I hear the slipping of the chain again, I will then change out the the entire transfer case and buy a new one. A new one at Cobra is $1,800. I'm not trying to be cheap about this, but I really don't want to spend $1,800 or even entertain a used one, as John from Cobra said about 1/2 of the TCs that they receive as cores have the chain guide studs broken like mine was. The chain guide was obviously a design flaw. Noteworthy - there are no marks on the inside of the case at all where the chain may have "slapped" the case. I'm sure the chain got loose enough to break the chain guide, but it didn't get loose enough to "slap" the inside of the case. I'm thinking about putting it together without it. If I got 170K miles before a TC issue, whose to say it won't last another 170K with a new chain and no chain guide.
Would love to hear anyone's thoughts on my proposal. Below are the pics:
You bring up some great points. And you're absolutely right, we cannot assess what Cobra has done with regards to transfer cases as statistically representative. They are only seeing the TCs that have had problems. Mercedes has the GL, ML and R classes that all use the ITC (Integrated Transfer Case). And you're right that getting a used lower milage transfer case is a good option as a replacement vs a rebuilt or new. My assessment of used transfer cases above is flawed as Cobra is only getting transfer cases that have had problems. But the vast majority of transfer cases out there are working as designed and getting a good used one is a good option for someone in this predicament. This transfer case design in general is a workhorse and provides the 4matic transmissions in these and other vehicles excellent all wheel drive capability. I guess I was giving Cobra some credibility because they weren't trying to sell me a new case, a rebuild kit, the planetary gears or even the bearings. He got to the point of the matter and said the chain stretches and that's what causes the skipping or grinding noise in these TCs. He recommended getting the chain, chain guide and seal kit. The transfer case itself is built very strong and there are very few cases of this TC itself damaging to the point of catastrophic failure. More often than not, the seals will leak due to age and wear, and the chain will stretch causing the skipping or grinding noise. Also, the chain guide will often break off from one or both studs as a result of the stretched chain. There are some forum members who have drilled into the studs to install the chain guide - some have even drilled to the outside of the case and epoxied it. This may work as well, but I don't want to risk drilling into an already weak structure (chain guide studs) to install the chain guide that's already broken off and possibly risk the guide messing up the chain, gears or seals - or create a future fluid leak. The transfer case structure itself is a beast. That's why I'm considering just putting it together without the chain guide because the case itself is extremely strong and my bearings and planetary gears are in great shape. I'm planning on driving the car for a long time. I've had it since new, so I know everything that's gone into the car. I usually replace with OEM or better parts to keep it lasting for a long time. But I'm also willing to assess the situation and realize that the transfer case is extremely strong and the only weak links are that the chain eventually stretches and chain guide is poorly designed and can break off. Considering all of the above, I'm now planning to put it back together with new seals, new chain and leave the chain guide out. As a disclaimer, I am not recommending other folks necessarily do this, but after my research and examination of my cleaned up case, gears and bearings, this is what I'm going to do. I'll report back here in the future and let everyone know how it worked out. Thanks again!
The site is www.tcbmwx5.com and his email is tcbmwx5@hotmail.com. He provided a great refurbished Transfer Case for $1300 and will provide a credit of $300 when the core is returned.
If you need a great product at a great price, give him a try
James
James
Thank you.
Ricardo.
I replaced the TC chain and the three seals. The new transfer case chain has about one year and 20K miles on it and is working perfectly. Car has almost 210K miles and is running strong - It's my daily driver. If you don't want to go through the hassle of the three seals, you could likely get away with just replacing the chain and then using sealant to put the case back together.
James
I would like to thank JamesMitchell for all the help and tips.
It is not necessary to remove the TC from the car.
Attached some pictures.
I'm preparing to take on the transfer case repair, hoping it is just the chain and/or minor fixes to the guide I'm over 220,000 miles and it recently started knocking occasionally on hard acceleration so I have been babying it. I had a few questions before I tackle it:
- Is it better to have the car on jackstands rather than ramps so the wheels can move? It was unclear to me if I might need to manually turn the drive shaft at some point for accessing things.
- How much more difficult is it to remove the entire transfer case vs, pop off the cover, replace chain and reseal? The idea of potentially working on repairs of things like the chain guide while under the car seems challenging but if getting to those rear bolts adds a ridiculous effort perhaps I try removing just the cover first and assess the situation.
- Is a high torque impact wrench useful? I saw a guy on youtube posted using a crowfoot and extension to get at that those back bolts which I think would negate any benefit of an impact wrench, but perhaps it would be useful for other bolts or maybe there is some flex joint I could use in combination with it. I've never really used an impact wrench at angles so not really sure the best way to do that or if that is practical.
- Does anyone have the torque requirements when re-assembling?
Thanks,
Max
Good Luck!
Thanks,
Max
I was pleasantly surprised to see my chain guide still intact despite some loud noises when accelerating especially up a hill. It appears to look different than others I have seen that seem to be more plastic. I am assuming maybe just a different version, but if it looks like the plastic wore off and I need to replace this let me know, the bolts are still intact so that would be an easy swap.
Other than cleaning up the inside and outside of the transfer case (is brake cleaner fine?), checking that there is smooth movement, replacing the chain and refilling is there anything else you'd suggest doing while I have it out?
