GL320 CDI in limp mode engine light on
Old Jul 22, 2017 | 03:26 PM
mariusz45's Avatar
Mercedes GL 320 CDI
I have 7 falt code , P0245- turbo wastegate selenoid A low, P2009-intake manifold runner control circuit A low, P0489-exhaust recilculation control circuit A low, P0111-intake air temperature sensor 1 circuit range/perfomance, P0100-mass or volume air flow A circuit, P1111-? , P1100-?
Old Jul 22, 2017 | 08:04 PM
DennisG01's Avatar
'08 GL 320 CDI
I can't offer technical guidance on this, but standard practice is to clear the codes, see if that allows full control of the vehicle and also to see what codes come back. Especially since nothing else is known about your vehicle and whether or not some of those codes have been in there for some time.
Old Jul 23, 2017 | 01:23 PM
mariusz45's Avatar
Mercedes GL 320 CDI
I cleared the codes and all 7 codes came back right away. Car is in Canada, the weather is very humid right and is around 80F outside. The car is accelerating very slowly as if the turbo is not boosting.
Old Jul 24, 2017 | 09:29 AM
a2j's Avatar
a2j
2008 GL320CDI (310k), 2017 GLS450 (170k), 2024 Sprinter 2500 (40k)
When was fuel filter changed?
Old Jul 25, 2017 | 07:22 PM
Fourdiesel's Avatar
2008 GL 320 CDI, 2004 VW V10 Touareg TDI
Lack of turbo boost(by itself) will NOT throw a code. On mine the pipe from the turbo out to the intercooler popped off! Had virtually NO acceleration but no codes were tripped.
Old Jul 26, 2017 | 08:40 AM
marc hanna's Avatar
2023 GLK250, 1987 560SL
To help diagnose, check to see if the turbo actuator is functioning properly. This can be done by disconnecting the linkage and giving it some throttle to see if the arm moves. If not, you will likely have to perform this repair:
https://mbworld.org/forums/diesel-fo...tor-again.html
Old Jul 31, 2018 | 10:17 PM
Nathan Baltus's Avatar
GL 320 CDI
mariusz45 what did you end up finding. Almost exactly one year later, in Canada, same issue....exact same codes.
