A/C stops working randomly
It seems to occur more on hot (100F+) days, although it has happened on cooler days too and doesn't have any issues on some days. The problem only happens after car has been driven for a little while. It never fails to work when the car is first started, and when it is working, it cools really well.
Any guesses what might be going on? Faulty pressure switch? Bad electrical connection somewhere? Thanks for any help - driving around in our recent 105F+ weather without A/C isn't pleasant.
You may just need to have it serviced to see if it's a little low on freon
I had a similar problem on a previous car with the A/C cutting out on hot days while parked (I think the system was slightly overfilled), but this happens at any speed. I'm going to take it back in and see if the dealer has any other ideas, but since the problem can't be reliably reproduced (has worked fine for 5+ days now), it is hard to diagnose/fix.
