Replaced my leaking injector seal, here are the steps and lessons (GL320)
Old Apr 19, 2018 | 04:05 PM
johny75's Avatar
'08 GL320
Originally Posted by smiledr996s
... I used parts from cb engineering.
I saw the dpf delete pipe on their site, I noticed that it does not have ports for the dpf sensor and fuel lines. Once the dpf was deleted from the ECU, when you installed the CB engineering pipe, do you know if the sensor and lines just hung next to it with a zip tie , for example, or something else was done. Thanks
Old Apr 19, 2018 | 06:01 PM
smiledr996s's Avatar
2008 gl320cdi
I did not install. I am pretty sure just zip tied. I plan to have the car dropped off soon to a mechanic. When he has on lift I will check it out.
I need to have have some bushings replaced and general maintenance.
Old Apr 19, 2018 | 07:17 PM
johny75's Avatar
'08 GL320
that would be great, thank you!!
I am getting close to pull the trigger and delete dpf, etc
keep me posted...
Old Mar 31, 2021 | 06:17 PM
barkinaksoy's Avatar
w211 2004
Hello, today i replaced my w211 e270 2004's fifth injector seal. But still there is a leaking voice i think forth one also leaking.
mu question is how long or how many km later can i understand is it successful replacement or not ?
Thank you.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
