2010 GL450 wont start
I have a 2010 GL450 which will not start. I put the key into the ignition and dash/command light up but turning the key there is nothing. no crank sound at all. for the past couple of months I have had labored starts where it struggles to turn over.
Tried jumping to make sure i had enough voltage for relay/starter.
Any suggestion on what could cause or next thing to check?
thanks!
thanks!
Start with the basics----voltage\any fuses blown and then will it crank when voltage is applied directly to the starter?--Do you have any diagnostics to test the starting circuit? No, then find someone with DAS Xentry diagnostics to make a house call.
